Old 10-13-2014, 07:40 PM
larryp larryp is offline
Default New guy again, hdy lever trouble
Hi, could one of you guys help me with my hdy lift levers on my 149, the lever on the other side of the hdy ram, that lifts the mower deck, is 1in or more lower then the other side, so when i lift the deck, one side is a lot higher then the other. these attach to the mule arms with a sliding attachment. i need to get them level. Thanks
Old 10-13-2014, 07:43 PM
IHCadetCollector's Avatar
IHCadetCollector IHCadetCollector is offline
I think a pic would help. I'm having a hard time fully understanding what you are saying. It may be one of those things where you understand it but it is difficult to explain.
I lost track of what I own a long time ago!
Old 10-13-2014, 07:53 PM
Ok, your talking about the lift arms on the rockshaft. You either have a very bent arm, or a sheered spirol pin on the rockshaft that holds the arm to the shaft.
#18 and 19 both have pins through them.
Old 10-13-2014, 08:04 PM
Attachment 57564
Do you just have those exploded views saved on your computer? I have a parts catalog, I just wish it was digital.
Old 10-13-2014, 08:26 PM
There are gobs of sites. All cub parts catalog's are digital.
Here's two:
partstree.com
cubcadet.com
Old 10-13-2014, 08:32 PM
Default hdy arm
you are right, it is the # 18, i beat on it with a hammer, and it moves a little bit, but not free, like a sheared pin would be, looking across at the other arm, it is higher, maby 1in. any ideas on making them the same?
Old 10-13-2014, 08:36 PM
Yes, change the pin. It's bent or sheared. Hole could be wollered out too.
Old 10-14-2014, 07:39 AM
Default hdy arm not level
I will remove the pin today, Thanks for the help
Old 10-14-2014, 09:22 AM
my hdy lift levers
What is "hdy"..........
Old 10-14-2014, 10:22 AM
TheSaturnV's Avatar
I just now got it: "Hydraulic"
