Thread Tools
Display Modes
My exhaust/air duct assembly is broken in several areas and I'm wondering if anyone has removed it permanently. What problems would this cause?
Steve 1450 QA42A Thrower 44A Mower |
The biggest problem would be over heating. I repaired mine with aluminum plate stock and JB weld till I could find another one. Which I did find another one on Epay but my repair is still holding so haven't changed it yet.
P1030684.jpg P1030685.jpg P1030686.jpg P1030687.jpg P1030688.jpg P1030689.jpg
1977 1650 with cast iron lower grill housing, cast iron oil pan, 54" push-snow blade, rear blade, disc-harrow, 44c and 48" decks, Two cultivators, #1 tiller with both extensions, loaded tires, 75' weights and chains, #2 cart. |
I removed the unit from my nephew's 1200. There has been no problems this year at all from doing that. There is plenty of air moving forward thru the motor from the flywheel to dissipate heat out the front of the grill.
DWayne 1973: 128, ag tires, 3pt. lift, spring assist, lights, 42" Deck 10" moldboard plow 2016 XT1 42" deck 18HP |
I just got done welding up all the cracks in my 800 sheet metal. Is yours breaking elsewhere? Search some threads on the "muffler crutch"
I currently have a donar k321 in my 1200 till I get my k301 back together and I didn't put the tin work or muffler box on it. I mowed for about 2 1/2 hrs with it and didn't have any issues. It may cause problems though the more you use it , don't know.
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake! ![]() |
