Old 10-08-2014, 09:32 PM
crossingcrown's Avatar
crossingcrown crossingcrown is offline
Default Are there parts interchangable between the 1250 and 129??
Are there interchangeable parts for these guys?? I am looking at the rear end in particular.. It is a long crazy thing here.. I am really hopping that it wont be to much to be asking..
Are the axel and hydro of the 129 compatible with the 1250..
The fronts are diff. I know this, so I cant engine swap. I cant afford the Hy-tran, filter and gaskets for the 1250 quite yet.. it looks like they could swipe out with out to much trouble.. And that is just nuts and bolts.. I can do that..
For all who are dying to know.. the guts of my valve feel in the 1250's hydro..
I don't know when it did.. All I know is that it wouldn't go in revers.. So I need to take it apart.. thus,, mentioned above.. can the back ends be swapped??
I am broke, but I make it work!
Old 10-08-2014, 09:37 PM
Are they both the equal machines? In other words, are they both manual lift, both hydraulic lift, or are they opposite?
Old 10-08-2014, 09:46 PM
both manual..
Old 10-08-2014, 09:48 PM
The hydro's are the same then.
Do they both have the same brake set up? Or is one internal and one external?
Old 10-08-2014, 09:55 PM
They are both external.
Old 10-08-2014, 09:58 PM
Then the rears will swap also. You can change either the parts, or the unit as a whole.
