Old 09-27-2014, 11:44 AM
stetson man stetson man is offline
Default 1872 won't shut off
Hello folks,
I haven't posted for a while, but I have a problem with my 1872.
First, I'm not electrically inclined.
The problem started with the PTO quit working.
I tried a different PTO switch, but that did not work either.
The tractor would start and shut off ok the first couple times.
Now I have to idle it down and choke it to shut it down.
I have tried a different ignition switch with the same results.
I'm not positive the any of the switches are good that I tried.
Is there a way the check the PTO & ignition switches with a meter?
If money was not an object I would just buy new switches, but I think that's why I have extras now that came with the tractor.
Thank you in advance.
Bob
Old 09-27-2014, 01:22 PM
In order to shut the Magneto off on the 1872, it has to be grounded via the Ignition switch. In the OFF position, there should be a path to ground (M + GRD) to kill the engine.
This same Ignition Switch supplies power to the PTO Circuit (B + R).
