I have found two possible procedures for repairing the fitment between the steering arm (pitman arm) and steering knuckle.
1) taper pin http://spaco.org/loose.htm 2) drill oversize and new spiral pin or bolt http://www.************************.com/steering.htm (scroll 1/2 way down page) Looks like OCC doesn't like that link... ![]() Which method is preferable? regards, Alan |
The bolt method is the worst because it will never fit the hole tightly and it will end up wearing the hole even more. I repaired my 100 using a tapered pin. If you go that route, you'll also need the correct tapered reamer too.
Adam 1964 Model 100 w/ K301 12hp and custom hydraulics 1972 Model 149 turned 129 w/ K301 12hp, triple hydraulics, 66 series clone |
I've always drilled mine and used a larger roll pin.
