Old 09-15-2014, 10:31 AM
Steve149's Avatar
Steve149 Steve149 is offline
Default What Deck is this?
The ID tag isn't on the deck anymore and I was just curious to find out what the model of it is!
there are a couple places that need new metal due to rust thru and bad weld jobs in the past from PO.
Old 09-15-2014, 10:40 AM
jimbob200521's Avatar
How wide is it, blade tip to blade tip? That'll tell you what it is. AFAIK, those were only made for 1/2 PTO's, so there shouldn't be a lot of confusion in that respect.
-Ryan
Old 09-15-2014, 10:57 AM
Steve149's Avatar
it is about 48" there abouts tip to tip
Old 09-15-2014, 11:05 AM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
NF 48" deck.
48" deck has welded on wheel brackets.
42" deck has bolted on wheel brackets in same spot as 48" deck.
38" deck has bolted on wheel brackets inside rear tires of tractor.
Old 09-15-2014, 11:09 AM
Steve149's Avatar
Originally Posted by DoubleO7 View Post
NF 48" deck.
Is there a model # associated with this.
Old 09-15-2014, 01:11 PM
48u1111
48u1112
48u1113
48u1114
48u1115
Yours looks like a 3
Up to 534 and counting...
Old 09-15-2014, 01:23 PM
Steve149's Avatar
48u1111
48u1112
48u1113
48u1114
48u1115
Thanks I was just curious
Old 09-15-2014, 02:47 PM
Those are the best mower decks IH made IMO.
Old 09-15-2014, 03:46 PM
Steve149's Avatar
I will tend to agree in part as to how freekin heavy it is to hoss around! There are a couple of bad spots which I am going to cut out and weld new in. Plus I have been following Adam's deck restore thread and going to do the new gauge wheels as well.
