Old 09-14-2014, 11:35 AM
Tacosteelersman's Avatar
Tacosteelersman Tacosteelersman is offline
Default Non running 1512
I took a gamble on a non running 1512 w/a Kubota diesel, with 947 hours. I had my eye on this tractor for over a year and a couple days ago finally caught the owner at the right time to inquire about it. He said it was parked due to the steering issue, and yes it has a problem there. He wanted more money but when it wouldn't start he said 400$ and get it out of here, so I did.
It has a mower deck that looks to be 48" the tractor needs a lot of maintenance items due to neglect and sitting.
So here is my list of updates before trying to start the beast again
Fuel line, prefilter, and other filter in sight glass, also checking the tank screen.
Air filter
New battery, cables, and glow plugs including the solenoid update
Oil change and filter.
I'm looking for any and all other suggestions.
http://onlycubcadets.net/forum/attac...1&d=1410708194
Front view
http://onlycubcadets.net/forum/attachment.php?
attachmentid=56433&stc=1&d=1410708316
Hour meter
http://onlycubcadets.net/forum/attac...1&d=1410708505
Left side view
http://onlycubcadets.net/forum/attac...1&d=1410708667
Right side view
I want to wait on the starter upgrade cause I have to do the alt belt and front rag joint and I would like to do them at the same time.
3 original cubs
1512 diesel
Ingersoll 3012
John deere 855
Old 09-14-2014, 11:50 AM
Wow, you got a deal! How is the other part of the driveline? Your off to a good start with those repairs. Keep us posted.
Old 09-14-2014, 12:10 PM
The linkages and levers all seem to work, the hydro is down right dirty the cooling fins can not be seen through the grime, I will get all that cleaned up still no visible leaks. That is another item on the list, hytran n filter change and steering gear adjustment or rebuild.
3 original cubs
1512 diesel
Ingersoll 3012
John deere 855
Old 09-14-2014, 10:53 PM
red56turbo's Avatar
Yep, I agree with Todd. You've got a good list to follow. You stole that diesel. Congrats!
Josh
Diesel Cub Cadets...........
Old 09-15-2014, 08:46 AM
Thanks, I think of It as more of a gamble than a steal. If I get outa work early enough today I'm goin shoppin n hope to get started on this project I am not really fimilar with diesels but I know basics on them.
Here are some dirty hydro pics.
3 original cubs
1512 diesel
Ingersoll 3012
John deere 855
Old 09-15-2014, 07:39 PM
Today I put on new fuel line, and both filters. Oil change with rotella and napa gold filter. New 420 CCA battery. I'm gonna call it a start.
I ordered glow plugs, and an air filter, I also bought 15' of positive and negitive 4 gauge cable and 10 ends I am going to try my hand at crimping. Lol
Dirty hydro
3 original cubs
1512 diesel
Ingersoll 3012
John deere 855
Old 09-17-2014, 07:09 PM
Ok so I installed new NGK glow plugs, although I used the old glow plug wiring for now. I made and cleaned the grounds including the block to frame cable.
I turned the engine over and no start. The fuel lines have been bled at the filter, at the high pressure pump, and at the injector I am getting no more air and fuel is present.
The exhaust smokes like a dark grey, not quite black.
I did notice something I thought was unusual. When my electric fuel pump comes on the small fuel line going from one injector to the other pushes fuel out. I pulled that small line off of the back of the injection pump and it is pumping out of the injection pump without the engine turning over. Is this normal?
3 original cubs
1512 diesel
Ingersoll 3012
John deere 855
Old 09-17-2014, 07:23 PM
444idi's Avatar
444idi 444idi is offline
i think new rubber lines are needed once they are disturbed they never seal
Old 09-17-2014, 07:28 PM
444idi's Avatar
and you should try 1 of the better looking glo plugs hooked to the harness to see if it gets hot or do a voltage test on the harness
Old 09-17-2014, 07:29 PM
Yep that is the return to the tank.
