Old 09-13-2014, 10:49 PM
gdheck's Avatar
gdheck gdheck is offline
Default Connecting the temp gauge on a 1782
Where are the wires on the temp gauge for my 1782 supposed to be connected? This is a 1996 model and I don't see the gauge listed on the wiring diagram. It has a black wire on the right side of the gauge, as you sit in the seat, that wasn't connected to anything when I got it. I have several things to do to it this fall and making the gauge work is #1 on the list followed by the starter upgrade.
Thanks
2 Originals, 100, 105, 125, 1450, 1200, 2 IH 982's, 1211, 2072, 2-1864's, 1782, 3 - 42" front blades, 3 Haban 54" blades, Haban sickle mower, BB36, QA-36A, 42" IH rear blade, 42" IH landscape rake, #1 tiller, #40 box blade, 59M shredder, #2 cart, International 3312 push mower, International 250 power washer, 1952 IH refridgerator, 1971 IH 1210 3/4T 4x4 truck
Old 09-14-2014, 07:03 AM
If you have a temp gauge on a 1782 it's a PO mod. 1782's have idiot lights.
Old 09-14-2014, 08:07 AM
gdheck's Avatar
Know what..........you're right! I never looked it up in the parts book because I assumed it was original. That is one PO that did a nice job of something. In that case, I'll just replace it and be done.
Thanks
Old 09-14-2014, 08:12 AM
Post a couple pics maybe we can figure it out. I put gauges in both my 1782 and 2182. 1st pic is the 1782, 2nd is the 2182.
Old 09-14-2014, 08:24 AM
gdheck's Avatar
This gauge is almost exactly where the center gauge is on your 1782 is. I like the location because I also like the idiot lights for a little extra security if they work. The low fuel light has saved me some headache a couple times. I still have a hard time remembering to check the fuel level because I'm too used to gassers.
Old 09-14-2014, 08:33 AM
Is your gauge electric or mechanical?
Old 09-14-2014, 08:45 AM
gdheck's Avatar
It's electric, but it just might become mechanical now that it isn't anything original.
I also just sent a question to my nearest Kubota dealer about adding a tach. to my 1782. I should know within a couple days if there are parts available to do this. When I have ear plugs or muffs on I have a hard time telling how much I'm working the engine unless it starts smoking.
Old 09-14-2014, 08:59 AM
This would be a typical way to wire up and coolant Temperature Gauge....
Old 09-14-2014, 09:15 AM
You sure about that Roland? The electric gauge I have in my 2182 has a lead from the ignition switch that is powered and the sender is basically grounded.
Old 09-14-2014, 09:43 AM
Better....???
