Old 08-24-2014, 10:36 PM
EarlJ's Avatar
EarlJ EarlJ is offline
Default Question....
I was wondering if anyone knew how long the lift arms are on a factory 3 point hitch? Or the optimal length on any 3 point?
126 in surgery with weights, spring assist, 3 point and sleeve hitch
100 with woods finish mower and rear lift,
Nice 125 with super nice sweepster, 1782 Super Diesel,
1650,782D in surgery, 102 parts tractor..
3 Brinley plows, Brinley cultivators , rear scrape blade, front plows and custom built bedder attachment.
Old 08-24-2014, 10:48 PM
Which model?
are you inquiring about the brinly sleeve hitch?
Up to 530 and counting...
Old 08-24-2014, 10:52 PM
red56turbo's Avatar
Cat O three point hitch????
Josh
Diesel Cub Cadets...........
Old 08-25-2014, 10:38 AM
EarlJ's Avatar
Yes çat 0 I saw a setup built allowing the use of the Brinley set up still. His lift arms look to be too long. It's a pretty neat set up because it uses the upper portion of the rear lift via the pin hole.
Old 08-25-2014, 10:53 AM
bolivier's Avatar
bolivier bolivier is offline
I saw that on facebook too. Cool idea, but I think it needs some tweaking. For one when finished it was sitting on the ground. I can tell by looking at it that it's not going to lift high enough to do anything. I think his arms look really long because on a normal cat 0 the arms go under the tractor a little bit, where his only go the back of the rear end. I think he was onto a good idea, but all the kinks are not worked out yet. I'll go out it a minute and measure my lower arms if nobody beats me to it.
Old 08-25-2014, 11:01 AM
bolivier's Avatar
My lower arms are 21" long. This is on a factory 3 point on my 2082.
Old 08-25-2014, 06:26 PM
EarlJ's Avatar
Thanks, yeah I think his are way too long. He does have a pic of it mounted. I am thinking he's going to have to adjust the turnbuckle up some more to get decent lift with the arms that long. It may surprise us though and lift 1000#....
Mind you I don't think so but would be cool if it did...
Old 08-25-2014, 08:48 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Nope. It takes a lot of tweeking to make the lift travel right and still have enough umph to lift anything. It might be lucky to lift 250 lbs... just my .02
Also having the arms out that long puts your attachments really far back, not a good thing, moves the weight far enough back that it takes the front end off the ground if the hydraulics will lift it
Old 08-25-2014, 11:57 PM
bolivier's Avatar
Agreed. I think it's going to lift more like 100 lbs tops how it is set up now. Again, great idea. Just needs a little work.
