Old 07-31-2014, 07:56 PM
Diesel Krazy's Avatar
Diesel Krazy Diesel Krazy is offline
Default Original fuel bowl?
Our new to us Original, has a fuel leak at the glass fuel bowl after removing it for cleaning, it was not leaking before. I guess that's what I get for trying to properly maintain a 52 year old tractor. It HAD on it what looks like standard gasket material hand cut to make the gasket. I got out my roll of gasket material and cut a new gasket out and installed it and it still leaks. I cut another new gasket out, both were cut perfectly. This time I put High Tack sealer on both sides of the gasket, it still leaks. Is the original gasket made from a different material? Maybe rubber? Any ideas? Should I try to cut one out of a inner tube from a tire? I'm not sure if the new gas of today would eat the rubber or not? Thanks for any help or opinions.
Original- Wheel Weights, AG tires, Brinly Sleeve Hitch, #2 Cart
882- 50c Mower Deck
2182- 60c Mower Deck, Rear PTO, Cat 0 3-Point, Brinly 60" rear blade
Case 646 FEL
Case 446
Old 07-31-2014, 08:03 PM
Billy-O's Avatar
Billy-O Billy-O is offline
I'm thinking of an o-ring!
Plow blade
#2 Cart
QA36 snowthower
Old 07-31-2014, 09:19 PM
Can't speak to the original but most sediment bowls have a cork gasket
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 07-31-2014, 09:32 PM
You can buy new sediment bowls. They look the same as they always have. The old pot metal gets pitted and you won't be able to stop the leak. Just replace it. Napa sells them.
Old 08-01-2014, 08:08 AM
Thanks for the replies. I did find a new one online last night that looks like an exact replacement for $12.00. I was trying to go cheap and just repair the gasket but I also don't want to deal with the leak again and again. I will try Napa for a new sediment bowl. Thank You
882- 50c Mower Deck
Case 646 FEL
Case 446
