Old 07-22-2014, 08:22 AM
Steve149's Avatar
Steve149 Steve149 is offline
Default Battery hold Down
Ok I got this from Patton Acres yesterday and either I'm not awake or something isn't quite right here. There is a hole for the hook to go in for the bolt and wing nut on the rear of the battery compartment but the other side of the battery compartment there is nothing for the bent part to fasten to. It catches on the lip of the compartment, but to get the wing nut on I would have to bend the hold down to allow the nut to be put on. Seems to me there should have been a hole for it to slip up into to work properly. I haven't had coffe yet so don't laugh!
Old 07-22-2014, 08:31 AM
sawdustdad's Avatar
I usually grind down the "hook" end to fit better. I guess it's made for various battery sizes?
Old 07-22-2014, 08:34 AM
Steve149's Avatar
That is what I was thinking because it doesn't seem right to have to bend it to fit! So that bent end just hooks under that lip?
Old 07-22-2014, 09:10 AM
Yes, it should just hook under the lip
Old 07-22-2014, 09:53 AM
Steve149's Avatar
Good deal I will have to eyeball it and prune a bit off the end
Thanks Guys!!!
Old 07-23-2014, 11:21 AM
Ash_129 Ash_129 is offline
Thanks Guys!!!
I had to do the extact same thing, Steve. Battery height differences must.... may be behind the design, as mentioned.
Cub Cadet 129
48" deck - grass mowing
38" deck - backup deck
42" front blade
Old 07-23-2014, 11:35 AM
Steve149's Avatar
I looked at this last nite and it is a difference in the height of the battery. And as near as I can tell i would have to cut off all but just a smidge of the end...this isn't cool. All it needs to work is a place for that end to go into...i was thinking about grinding a flat on a washer and tacking it in place for the end of the hold down.
