Old 07-22-2014, 12:26 AM
cc_bob cc_bob is offline
Default Cleaning carbs
Here's something you may not know. You can use Pine-sol to clean carbs and it works great.
All you do is disassemble the carb, put the parts in a container and fill it with Pine-sol (the real original formula) until it covers the parts. You then let it soak for at least 24 hours, take it out and wash it under warm running water (when the wife isn't looking). Any grime still left on it comes right off with an old paint brush.
Sorry this is not a Kohler carb but it's the only one I have a pic of. This one was covered in grime and varnish. The throttle plates were caked with carbon and the inside of the bowl was really bad. I let it sit in the bucket for a day and just took a stiff paint brush to scrub it off.
This is it's pretty much harmless to you and the environment and it's really cheap. I just strain it and put it back in a jug when done to use it the next time.
I like to keep em running and work them.
1872 (I call her Vera), 782D, 154 Loboy (w/tiller, 3260 deck, and front blade), 3-1650s, 2-1000s, 149, 147, 106, 1810, Farmall Cub, Haban sickle bar (not mounted), No. 2 trailer and several parts tractors.
Old 07-22-2014, 01:08 AM
Honestly I did not know that.
What are you doing rebuilding a Rochester anyway? Those things aren't worth the time!
Seriously, I've always had good luck with them, but Edelbrocks are so cheap to buy.
Old 07-22-2014, 09:29 AM
Sam Mac Sam Mac is online now
Great tip on the cleaning.
Not to hi-jack your thread but I never cared for Rochester or Edelbrock carbs. This one was may fav. BLP/Holly setup for road racing, flowed 915CFM.
Old 07-22-2014, 05:56 PM
I've had good luck with them too, considering how old most are when I get them. The rebuild kit was only $30, for a stock 350 they work just fine and it leaves more $$ for other toys.
That's a bit more carb than my truck would ever handle. It's just an old square body.
Might as well push this thread right off the tracks
Here's what the carb was for, note the brown on the fenders is RUST, I used molasses to get it off.
Here's what what she looks like before I put all the trim back on. I need to take some more of it now.
Old 07-22-2014, 10:08 PM
rwairforce rwairforce is offline
Wow, what a difference. Good job.
Pine-sol and molasses....I expect to hear something great from KY-syrup..maybe buttermilk..LOL
I'll certainly try the Pine-sol...the price for those 1 gallon cans carb cleaner has gone through the roof. Thanks for sharing.
Randy
Cubs: 71, 72, 127, 149, 1440, 2186 and 1864
John Deere 110 round fender
John Deere 140 H3
Sears: GTV16
Old 07-23-2014, 12:32 AM
I'm a Holley w/mechanical secondaries fan myself if EFI is out of the equation for some reason... Or an autolite of the correct vintage depending on application. I've never had much luck with Q-Jets..
Since the topic is running WAY off the rails anyhow, I've never used Pine Sol to clean parts, but my mother started using it (a few cap fulls plus regular detergent) to clean my nasty shop clothes decades ago when I would come home covered head to toe in car "goo" as a kid. It works awesome there too and I've been doing it ever since.
Now I'm upset with myself that I never thought of it for parts!
Old 11-11-2014, 07:53 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
How did I miss this thread? I am definitely going to try this.
Now to derail again. I like the Q-jets. They are the best 4-wheeling off road carb there is. Holleys are good for racing. Just make sure you have the right float application for your type of racing.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 11-11-2014, 09:45 PM
garnold's Avatar
garnold garnold is offline
How would you compare this to a gallon of that Gunk carb cleaner? I use the Gunk but man that stuff can really put a beating on you. Even with rubber gloves I still get the stuff on me. Pine-Sol I think might be a little easier on the body.
108 upgraded to 12hp
127 with all the trimmings
73 WIP
75 WIP
Blade, blower, decks
Tons of left over parts
Old 11-11-2014, 09:59 PM
I don't like Gunk cleaners. Cheapo. There's better stuff. For carbs, I clean them by hand in the parts washer, then on to the jet tank, then bead blast. Seriously, cleaning carb is very tedious and time consuming when doing it by hand all the way. There's just no way around it. (Even my process takes a day to get one clean and ready to assemble.)
I will say, doing this is not for everyone. Not just because not everyone has a bead blaster..... but because if you don't clean it good afterwords, you can end up with glass beads in the motor. That = very bad.
Old 12-25-2014, 12:37 PM
Just used the pinesol to clean the Kohler carb I got Sunday, gotta say it worked well. Then I dumped the leftover pinesol in the shop toilet and scrubbed it out. Killed two birds one pinesol.
