Old 07-21-2014, 03:05 PM
Steve149's Avatar
Steve149 Steve149 is offline
Default Deck Question
Maybe this issue has been addressed at somepoint, but I haven't been able to find it through searching. I have a 48" deck on my 149 that is in need of some TLC; however, it still mows ok. The problem I have noticed is after setting the height adjustment the front of the deck is nosed down. When the deck is fully raised the nose roller is only 1/2" off the ground
Are the front hangers adjusted to low and causing this, or am I missing some other adjustment here???? I have seen other pictures on here and the decks appear to be setting level when fully raised.
Thanks!!!!!!
Old 07-21-2014, 03:29 PM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
Make sure the pivot arm (upper left one with the u-slot in the end of it) is straddling the lift handle cross shaft.
Old 07-21-2014, 03:32 PM
here is a manual for it,shows how to check for levelness
http://service.mtdproducts.com/Train...n/IH-GSS-1464/
Up to 530 and counting...
Old 07-21-2014, 03:49 PM
Steve149's Avatar
After looking this over I do believe the support clevis's on the front are the culprit here! Thanks a ton guys!!!! much appreciated!
Old 07-25-2014, 11:57 AM
Steve149's Avatar
I have noticed that on most decks I have seen on here there is an ID tag on the one end... unfortunately mine is gone...is there a reference available to determine what deck I actually have???
Old 07-25-2014, 05:52 PM
YUP... Show us pictures.
Old 07-26-2014, 08:58 AM
.....and measure it.
