Old 06-28-2014, 01:14 PM
Diesel Krazy's Avatar
Diesel Krazy Diesel Krazy is offline
Default 882 mower belt adjustment?
I have an 882 that has the 50" deck. It says 50c for the model. I installed a new belt and a new adjustment spring. I believe I have the proper size Cub Cadet belt from my Cub dealer. It seems like the belt is too long, mabe an inch. It works perfect but I am at the end of adjustment on the Jhook. J hook sticks out the front like 4". It also seems like the one pulley is closer to the front than it should be. Do I have the wrong belt? Does anyone know the proper size and part number Cub Cadet belt if mine is wrong? Do I mabe have the wrong mule drive bracket? Here are some pics. Thanks!
Original- Wheel Weights, AG tires, Brinly Sleeve Hitch, #2 Cart
882- 50c Mower Deck
2182- 60c Mower Deck, Rear PTO, Cat 0 3-Point, Brinly 60" rear blade
Case 646 FEL
Case 446
Old 06-28-2014, 07:14 PM
The Belt is correct.
I would suspect, that the tension spring for LH Pulley (facing mule drive) is not installed correctly, thus not putting the correct tension on the belt. Don't ask me how I know this.
Old 06-28-2014, 10:14 PM
dale c. dale c. is offline
what holes do you have the mower frame and the front idler pulley bracket bolted in? I know the rear holes are used for the supers but there are 2 other sets if I remember right
Old 06-29-2014, 07:40 AM
I have a new spring installed and can only see one way for it to be installed. Do you have any pics of its proper installation? Thanks
882- 50c Mower Deck
Case 646 FEL
Case 446
Old 06-29-2014, 07:43 AM
I didn't notice any extra sets of holes. I will check in a few minutes and see if there are more than one set of mounting holes. Thanks.
882- 50c Mower Deck
Case 646 FEL
Case 446
It installs only one way, but the "tang" has to be properly positioned to apply the necessary tension.
I'll see if I can take a pic's this morning and post it.
Old 06-29-2014, 08:45 AM
Here are a few pics if the deck and how it's adjusted.
882- 50c Mower Deck
Case 646 FEL
Case 446
Old 06-29-2014, 09:17 AM
The "tang" is in the same position as mine.
Is your Mule Drive Pulleys IH-132496-C1-----> 756-3003 being a 4" OD...???
Old 06-29-2014, 09:29 AM
Mule drive pulleys are 4" od and deck pulley is 4 5/8".
882- 50c Mower Deck
Case 646 FEL
Case 446
Old 06-29-2014, 09:37 AM
Is the "travel" on the LH (spring loaded) pulley free to move...???
