Old 06-26-2014, 10:17 PM
Fitz14's Avatar
Fitz14 Fitz14 is offline
Default Does anybody know what this is?
This came out of the bottom of the oil pan of my Onan engine in my 982. I haven't had one of these Onan's apart before. I pulled the left head off and took the piston out because of a problem I'm having with it and this piece was in it. It will only run on one cylinder. I've checked the valves and rings, tried a different coil and plug wire plus new plugs. I have set the points and cleaned the carburetor. The compression was 45 on that side and 120 on the other side with the engine hot. I adjusted the valves and it came up to 120 cold. I haven't been able to run it to warm it up. I'm going to try to fire it up again tomorrow. Just got it back together. I'm going to order points and condenser. Maybe that's the problem. The spark does look weak to me.
Old 06-26-2014, 10:29 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
I'll start out the speculation. it appears to me it was a circle at one time since it has a male tab on one and a female tab on the other. anything else in the pan , grindings, non metallic material ?
Old 06-26-2014, 10:33 PM
Fitz14's Avatar
Nothing else except the small piece in the first pic. No grindings or anything. The pan was clean as new.
Old 06-26-2014, 10:35 PM
kostendorf's Avatar
Its a wire tie that's supposed to be on the frame holding tubing or wire.
Old 06-26-2014, 11:11 PM
I think I would check a parts manual to see it there is anything in there that looks like that before I run the engine.
Old 06-26-2014, 11:46 PM
Billy-O's Avatar
Billy-O Billy-O is offline
Camshaft bearing, maybe?
Plow blade
#2 Cart
QA36 snowthower
Old 06-27-2014, 12:15 AM
Ya know..... it really does look like a cam bearing. TBH, I didn't know it had one, but the parts book shows it has one, on the front only.
Old 06-27-2014, 06:43 AM
Green stripe wide frame's Avatar
Green stripe wide frame Green stripe wide frame is offline
It looks like a broken dip stick to me.
Old 06-27-2014, 07:32 AM
I've never been inside an Onan but I'm going with a bearing also. I wouldn't run it until you find out where that came from or you may end up destroying it.
This is a good thread on Onan engines on My Tractor Forum
http://www.mytractorforum.com/showth...ne+cam+bearing
This is the guy that wrote it
http://www.onanparts.com/
Old 06-27-2014, 08:26 AM
dbuck dbuck is offline
Smile
After looking at the site Sam Mac posted from My Tractor. There looks to be a cam and crank bearing in that block. But the picture posted by Fitz14, if that is a bearing it does not look wide enough to be either a cam/crank bearing. But I would surely break that engine down, to try and find out where it came from.
Don B, USAF 1962-1968, Ft. Wayne, IN
