Old 06-20-2014, 10:19 AM
whatever 80 whatever 80 is offline
Default 1200 44A blade washer info needed
1200 with 44A deck. Finally getting back together. I have my 3 "bearing cups" and 6 large washers. Anyone know if there are washers on both sides of the blades??
I Can't find my take apart pix. And my parts look up doesn't show placement.
Thanks
(if this has been asked, please point me there)
Old 06-20-2014, 11:17 AM
Did you look here..??? http://www.onlycubcadets.net/forum/s...ad.php?t=24721
Old 06-20-2014, 11:38 AM
sbauerz28's Avatar
Thanks
All my decks go bearing cup, washer, blade, washer, nut.
Old 06-21-2014, 10:29 AM
Yes, on page 48 of 60, diagram doesnt show washers or nuts. BUT thanks though! I didn't have the other decks info.
Old 06-21-2014, 10:32 AM
Thanks, yah that's what I figured, just wanted a little confirmation. "pita" to redo after deck is on if i had it wrong.
Old 06-21-2014, 11:43 AM
Wanna know a secret?....... It doesn't matter. As long as all the blades are the same so they don't cut different heights. I have/seen decks with two washers, with one, with none. It makes no difference in placement as far as anything is concerned. I think they may have been there just to adjust how many threads stuck out the nut, or so that you can adjust blade height per spindle.
