Old 06-19-2014, 08:34 PM
Kratt's Avatar
Kratt Kratt is offline
Default Cub 126 Restoration Begins
Here we go. This summers project is a 126 I picked up last year. At that time I wasn't sure i was going to keep it, but I'm glad I did. This one had some issues. Here's a pic of the day I picked it up. You can see that the footrests are completely rusted out...all the way through. Can't save the fender...AND THAT SEAT!
Members of The Herd
149 Restored: Tilling Machine --- https://www.onlycubcadets.net/forum/...ad.php?t=27758
126 Restored: Just too pretty to use --- https://www.onlycubcadets.net/forum/...ad.php?t=32695
104 As Is: Snow Pusher.
102 As Is: Snow Thrower.
123 Currently Under Construction!!! --- https://www.onlycubcadets.net/forum/...ad.php?t=55593
Old 06-19-2014, 08:37 PM
Kratt's Avatar
Some teardown...
Members of The Herd
Old 06-19-2014, 08:44 PM
Great project tractor
Looking forward to your progress.
Old 06-19-2014, 08:48 PM
Kratt's Avatar
Last year when I was checking the tractor over, I noticed i couldn't get it into 3rd gear. I pulled off the shifter and found the main shaft TWISTED enough to be obvious to the naked eye. At that time got some great information from Tommyk on replacing that shaft. Shaft replacement was going to be part of my teardown. First pic is the twisted shaft. Second is what i found once I really took a look inside.
Members of The Herd
Old 06-19-2014, 08:51 PM
Wow I wish my 126 had all those options. Will be following your thread.
Old 06-19-2014, 08:54 PM
Kratt's Avatar
Second gear was the only one missing teeth, so a new (used) one arrived the other day. Here's the rest of the teardown up to today. In a couple pics you can see last year's project. Sure is pretty.
Members of The Herd
Old 06-19-2014, 09:02 PM
I just had my 800 trans fully apart like yours. Good job cleaning it out. It's cool how all the gears go back in with just enough room and the bevels certain ways. Did you have to take the carrier bearings off to get the carrier out?
Old 06-19-2014, 09:35 PM
Kratt's Avatar
Yep...the left one. No way it would come out with that on. Here's all the 'innards' put back together with extras off to the side.
Members of The Herd
Old 06-19-2014, 10:18 PM
Exactly.....Looks like your 126 was loaded!! Definitely worth restoring. Great work so far.
Old 06-19-2014, 10:37 PM
Kratt's Avatar
Once i get the last few pieces dismantled and lift the engine off the frame i can get the parts to the sandblaster. The 149 we did last summer was stripped by hand with grinders...Don't think i want to do that again.
Members of The Herd
