Thread Tools
Display Modes
So I originally posted under a 122 transmission problem but decided to start a new one with the correct title. Anywho, here is a pic of the teaser spring that needs to be replaced. Advice? I'm assuming that the motor will at minimum need to be slid forward to get at it for replacement. (realizing all of the associated work involved in doing so)
i would remove the engine, trying to work around it is more of a pain than taking it out. i usually put a pry bar across the frame to support the end of the drive shaft then beat the pins out with a hammer and punch, its that easy. DO NOT replace the original pins with standard roll pins as they will just snap off, unless you destroy them getting them out its ok to reuse the originals
