Old 02-27-2010, 10:43 AM
cricket cricket is offline
Default replacement engine for 125
Has anyone ever replaced the kohler 12 hp engine with larger?
Gas or diesel, how much trouble or work?
TFR
Old 02-27-2010, 11:50 AM
Aroostook Aroostook is offline
Smile
It's been done. At one time or another Everything has been done to these Cubs! However, your 125 is a Narrow Frame Cub and to even replace the 12hp Kohler with a 14hp Kohler, you'd have to relieve the frame to accept the larger flywheel on the 14hp. My humble opinion is that if your 125 doesn't have enough power to do what you want it's time to either rebuild the engine or find a 149 that you can buy.
Old 02-27-2010, 12:10 PM
MBounds's Avatar
MBounds MBounds is offline
Cricket: Aroostook may be a relatively new poster, but his advice is dead-on correct. I recommend you heed his advice.
Myron B
Old 02-27-2010, 01:04 PM
Talking
Thank you, Myron. That means a lot, coming from you!
...and look, I just got another post in.:biggrin2.gif:
Old 02-27-2010, 02:40 PM
gravest's Avatar
gravest gravest is offline
I've actually seen these with V-8 engines on them. It was most likely a wide frame though. Can't remember.
If one cub cadet is good, Two or more would be heaven.
Old 02-27-2010, 03:14 PM
placeebo effect placeebo effect is offline
if anything, put an ad in craigslist for a swap of machines. somone may be looking to downsize from a 14 or 16 hp machine. just an idea
Scott Larson
Climax,MN
Its not cold. its gods way of keeping the rif-raf out.
Old 02-27-2010, 07:16 PM
ihnick's Avatar
ihnick ihnick is offline
Can't you put a 12 horse flywheel and tin on a 14 horse. Thought I remember someone talking about that
Nick.
