Old 05-27-2014, 03:59 PM
Pfunk Pfunk is offline
Default 59M Shredder-Grinder
Looking for some help. I just purchased a 59M Chipper-Grinder. It all looks to be in really good shape, but part of the mount is missing. I've got a 2 X 4 replacing it in the pictures. It's parts numbers 6 and 18 in the parts diagram. I've never owned a Chipper-Grinder so all I know about the mount is what I see in the parts lookup. The parts are NLA, but I think part No. 6 would be easy to make if someone can supply me with some dimensions. I'm guessing the springs set on top of the two sections of pipe and don't go down inside them, but I'm not sure. Also I don't know the compressed or uncompressed length of the springs. Any help would really be appreciated. This thing is going to be great when I get it going!!!
Old 05-27-2014, 08:31 PM
mmzullo mmzullo is offline
I made #6 but intestead of springs I used 3/4 threaded rod and nuts. now I can put more tension on the drum by tightening on the rod and nuts.
Old 05-27-2014, 08:42 PM
Nice tractor and chipper shredder.
Old 05-27-2014, 08:52 PM
Yeah looks awesome mounted to the 73, lots of cool options you have also. Hope you get the pieces you need.
Old 05-27-2014, 09:36 PM
That's a very nice setup!
Old 05-28-2014, 12:29 AM
Mr.Goffena's Avatar
Mr.Goffena Mr.Goffena is offline
I will try to look tomorrow afternoon. You can see it in this pic.
107 with rear lift
1250 hyd lift. 682 diesel project
Original project
#2 and tiller
#2 trailer
59M sheader
home made boxblade
wideframe 54" snowplow
Old 05-28-2014, 06:45 AM
Congrats on the chipper Paul! Looks great mounted up to the 73!
Old 05-28-2014, 03:33 PM
Thanks for all the comments. I'm partial to the 70 series Cub Cadets. The 73 in the pictures also has a rear PTO. It's pretty well decked out and gets used a lot.
I really like the idea of the 3/4" bolts, but since I plan to have the 59M off and on a lot, I wonder if that won't become inconvenient. But, that's a great idea, and I may end up doing just that.
Any measurements would still be appreciated. I can make a good guess at the overall length as well as the dimensions of the bar but the closer I can get it to the real thing the better I'll like it. I measured the tubes and I'm guessing the two rounds welded to the bar are 3/4" diameter and probably about 3 inches long?
Thanks
Old 05-28-2014, 06:03 PM
garth68 garth68 is offline
top bar part is 10' 1/4 long the pegs are 3'' long and 3/4' thick hope this helps
Old 05-28-2014, 06:19 PM
Thanks, that's what I needed.
