Found a PTO from a 102 .
I want to put it in my original, will it work ? I guess im asking will the pto install into the rear diff of my cco
Doug Original , 100 , 125 , 582 ![]() ![]() ![]() ![]() West Central Ohio Farmall & Cub Cadet Club https://www.facebook.com/#!/groups/226681087497199/ |
Quick answer is no. Most of the parts are the same but the main trans shaft for a rear pto on an orig is different than the 102. I had to machine one from a full size cub to fit mine.
Well then I guess I have a PTO setup that I'll teade for a PTO for a CCO
or if you have any pics or more info on the mods to make this work?
Will the bell on my cco rear end fit the 102 rear?
Then change the axle covers for the brake setup on the cco
It's not the gear case that is the concern but the speed reduction housing that bolts to the gear case. The orig has a different reduction then the 102 . It has been several years since I made the top shaft for mine but if I remember correctly I cut the cub shaft off and machined a spline on the cut end. Hope that helps a little.
OK thanks , once I get both rears opened up on the bench I'll see what your talking about.
