Old 05-25-2014, 04:19 PM
gt383mag's Avatar
gt383mag gt383mag is offline
Default My 982D build
ok this thread is gonna take a while but here goes
got the 2082 tore down for sand and paint... not a fan of the rockshafts and brake shafts have one i couldnt get out at all
are these powder coated? the sander dont like it
File Type: jpg ResizedImage_1401048654742 (640x361).jpg (19.5 KB, 503 views)
File Type: jpg ResizedImage_1401048668526 (640x361).jpg (19.2 KB, 501 views)
Old 05-25-2014, 04:22 PM
gt383mag's Avatar
this kinda sucks since the seller said hydro is fine... anyone ever welded one of these? i think ill give it a try if it dont work out i have the one from the 782D. looks like im gonna have to put in another order to extreme. ill post again when i have more pics as the build goes on
File Type: jpg ResizedImage_1401048624950 (640x361).jpg (17.2 KB, 503 views)
Old 05-25-2014, 05:54 PM
Don't even worry about the broken mount, get a set of SGT braces from Xtreme, problem solved.
Old 05-25-2014, 09:01 PM
gt383mag's Avatar
thats what i was thinking
Old 06-10-2014, 10:02 PM
gt383mag's Avatar
spent last two evenings stripping and sandblasting the frame what a b#@%h must be powder coat found spray on chemical stripper that dont work too bad will post pics later
Old 06-11-2014, 09:07 PM
gt383mag's Avatar
finally got enuff paint off now to blast the flash rust out used stripper in a spray can worked pretty good but took several attempts in some places
File Type: jpg ResizedImage_1402534786825 (640x361).jpg (21.7 KB, 374 views)
File Type: jpg ResizedImage_1402534772582 (640x361).jpg (20.6 KB, 373 views)
File Type: jpg ResizedImage_1402534754136 (361x640).jpg (16.8 KB, 377 views)
Old 06-11-2014, 10:04 PM
Thanks for the pics and update.
Old 06-12-2014, 01:27 AM
OldSkull's Avatar
OldSkull OldSkull is offline
Is it a IH 982 (79-81) or a CCC 982 (82-85) ? This is a rare and nice bird, founding implements for it most be a PITA. Of all CC this is the one I wish I own brand new and an original of course :-)
Looking forward to see the progress you did on that gem, keep the good work
Gilles.
1963 100 (red)/in storage
Old 06-12-2014, 07:56 PM
gt383mag's Avatar
sorry for the misunderstanding i started out with a 782d and a 2082 and my final result will be basically a 982d
Old 06-13-2014, 07:29 AM
OldSkull's Avatar
This thread tittle is confusing but the mistake is mine since you clearly specify stripping a 2082 frame in your first post. It's a interesting build to follow and a unique bird repro.
I wonder what diesel engine ICC or CCC may have swap in the 982 if they had build one? What was available between 79 to 86? I bet they fit at less a 16 to 20hp if they could.
Gilles.
