Old 05-25-2014, 02:35 AM
uarobert's Avatar
uarobert uarobert is offline
Default Cub Cadet 682 KT-17 which engine?
Hey guys, I have a 682 kt-17--of course, and have had it for years. How can I tell if it a series I or series II engine. I never could find the plate on the left side where it should be. Are there any other obvious characteristics that will tell me?
Thanks, I've been off the site for a couple years but now I want to fix it back up.
Old 05-25-2014, 05:14 AM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
The series 2 has an oil filter, the series 1 does not.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 05-25-2014, 07:11 AM
Not true. I have a KT-17 Series II that has NO oil filter, right from the factory.
IF...everything is original, you can go by Chassis Serial Number of the tractor:
Series I #669971 to 726124
Series II #726125 & above
Old 05-25-2014, 07:34 AM
First off Welcome to OCC!
The series 1's did not have the block off plate on the block to hook up the oil lines. As Roland said the early series 2's did not have an oil filter but I thought still had the block off plate but don't remember for sure. I will have to look at some of mine to see.
Old 05-25-2014, 07:48 AM
On my Series II, there was no "block off" plate nor a provision for one.
I never have found a Kohler Reasoning to why some Series II had on oil filter and some did not. My "speculation" is, that is was buried into the "Specification" of the engine as to the buyer's requirements.
Old 05-25-2014, 08:40 AM
Yeah, I think you are right Roland. I have seen some series 2's with no block off plate provision.
Another thing to maybe look at is the oil fill. All the series 1's I have seen have had the square cap and all the series 2's I have seen have had the round filler cap. Not sure it's a proven fact but it is a usually a good place to look.
Old 05-25-2014, 08:53 AM
Darrell Darrell is offline
All the Series 1 i have seen had a pipe plug for the oil fill , and the Series 2 had a straight or angled pipe with a cap for the oil fill , if no one has changed it in it's life.
I have also seen them with/without the block-off plate.
Old 05-25-2014, 10:47 AM
SS5150's Avatar
SS5150 SS5150 is offline
Sorry to jump onto someone else's topic, but were any of the MTD built 6/782s series I's? Reason I ask is I found a white/yellow 782 close but I couldn't see a block off plate through the grill.
RUN IN THE RED
782 w/50c deck (red); 782 dual stick, 44c deck (y/w);
1050 w/38c deck; 1864 w/54" GT deck;
1872 project
Cub Cadet Pro Z 560 L
42" power angle snowblade, #2 tiller, 2-QA42a snowthrowers, 450 thrower, #2 cart; 54" Haban blade; Brinly box blade, 48" dethatcher, moldboard plow; Agri-Fab sweeper
1200, 1863, 1864 parts machines
Old 05-25-2014, 11:10 AM
red56turbo's Avatar
Just as was discussed above, some Series II had a block off plate, some didn't.
Josh
Diesel Cub Cadets...........
Old 05-25-2014, 11:30 AM
SS5150's Avatar
I was asking if series IIs started before MTD began production, (as in all MTD built units were built with series IIs) or at least that's what I meant. I was trying to figure out if it may have had an engine swap.
RUN IN THE RED
1872 project
