Old 05-23-2014, 11:15 PM
Default Steering alignment on a 149
Is there anything special to be done here? Just eyeball it in?
I MIGHT get around to swapping my front axle out this weekend for one that will accept grease (long story and the replacement was free) and replace all my highly suspect rod ends.
Old 05-23-2014, 11:28 PM
the rod from the steering coloum to the left spindle should be 16 3/8 inch from the ends of the ball joints, from there just use a tape measure and measure the front and back of the tire and adjust the rod till you get the same measurement
Old 05-23-2014, 11:36 PM
make sure when your measuring the front and rear of the tire to have the tape measure the same height off the ground for both. since the tires tip out at the top it will throw off your measurement if you dont
Old 05-23-2014, 11:40 PM
Do you put a touch of toe on them for steering center or just leave it even front to back?
Old 05-23-2014, 11:45 PM
i leave it even but a little toe in wont hurt
Old 05-23-2014, 11:59 PM
I believe the toe in should be 1/32 to 1/8 inch if I remember correctly from the service manual.
Not much, but some
Old 05-24-2014, 12:17 AM
Hummm.. I'll tinker with it within that range then. Right now the front wheels come back to center REALLY fast.. It may have too much in it already. I'll take a baseline and see where it stands out of curiosity.
Old 05-24-2014, 08:11 AM
dbuck dbuck is offline
Smile
On my CC149. I used. steel ball joint rod ends, with a self lubricating insert, on the steering arm and the drag link. They are also available with a grease zerk. I also intalled a super steer kit and with tri-ribs on the front it is like I have power steering. I bought the rod ends from McMaster-Carr. As for the tow, I use 1/8".
Don B, USAF 1962-1968, Ft. Wayne, IN
Old 05-24-2014, 12:19 PM
Nitro's Avatar
Nitro Nitro is offline
An easy way to get a good measurement is to bungee a 2x4 to the front tires and measure across that. That's how I set up my race car back in the day. Probably not as critical on a 9 mph tractor though.
Philip
1450, 1015, and a pile of parts.
