Old 05-22-2014, 06:40 PM
bolivier's Avatar
bolivier bolivier is offline
Default Dual hydraulic valve from John Deere 318
I think i've read something about this on here. Anyway green parts are cheaper than cub parts. I want to convert my 1650 to a dual stick of sorts. So I was wondering if I could adapt the 318 dual valve. Pretty sure it can be done. Just wanted to here what you guys had to say on the topic.
Thanks,
Brent
Old 05-22-2014, 07:04 PM
YUP, it can be done with some engineering, fabrication, modifications and some sweat.
Old 05-22-2014, 07:23 PM
IHinIN IHinIN is offline
Should be do-able. I used a 2 spool valve from a 317 JD when I added dual hydraulics to my 100. The nice thing about the JD valves is that they have float on one of the spools which is nice for the deck/ front blade/ 3-point lift.
Old 05-22-2014, 09:12 PM
bolivier's Avatar
IHinIN I remember your 100. I will definitely be going back to look at your work. Thanks!!
Old 05-22-2014, 11:35 PM
FlyingB FlyingB is offline
You can also use a JD triple valve off a 400 and make a triple stick. I plan on doing that this fall.
Phil
A nice 1710 and QA42A snowblower.....and more to come .
Old 05-22-2014, 11:47 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
I got one of those waiting to go on the 2072
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 05-23-2014, 09:48 AM
Berwil's Avatar
Berwil Berwil is offline
Me 3, I picked up a triple cheaper than a dual on cl. Just waiting for my play fund to recover before I install.
Bill
Old 05-23-2014, 11:00 AM
bolivier's Avatar
You guys have got my wheels turning now. If I get the triple I could have lift for the box blade. Lift for my Johnny bucket jr, and dump for the bucket too. The possibilities!!
Old 05-23-2014, 12:11 PM
I've got a triple spool waiting it's turn too. Cub Cadet 2 spool valve....$200-$250. Deere triple spool..... $80 on e-bay (mine was anyway). Usually the triples go between $125-$150. No-brainer here. BTW, I think they are Parker spools just like on the CC tractors. I think the dual spools will bolt and plumb right in.
Old 05-23-2014, 12:36 PM
Shrewcub's Avatar
I can't remember exactly, but I paid less than $100 for mine too
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1961 IH Cub Cadet O
