Old 05-21-2014, 08:07 AM
nikster's Avatar
nikster nikster is offline
Default Question on a 782 undercarriage?
Just DON'T. Know?
Does the 782 need a specific undercarriage to use so that a grass cutter can be attached?
Can a standard snow plow be attached?
Or how about a q36 snow thrower?
Granted these are a lot of questions but I'm ignorant in the workings of the reds?
NIK,
Eg; can a undercarriage from a 1250 or a 127 be used?
Old 05-21-2014, 09:41 AM
Nick,
The 782 will take any WF attachments. The front blade, or a QA snowthrower, 451 snowblower, but the mule drive needs to be one from the '82 series (what they called the "spread frame") or newer. Might need to adjust the length of the lift rods on the front attachments though, NBD. When they went to the twin cylinder, the mule drive changed a little. (We were debating the difference in the mule drives recently in another thread that I can't find.) The pulleys are in a different location for the spread frame tractors. All other attachments that came off the WF will work though, no problems.
Old 05-21-2014, 10:22 AM
nikster's Avatar
Thanks, GOOD to know.
I might have a local lead on one. Supposed to have 500hrs. on it & no undercarriage or deck? Was used in moving vehicles & boats in a storage facility?
Nik,
Old 05-21-2014, 10:49 AM
Good luck Nik! Maybe this one will "fall" into your lap better than the other one.
If you get it, Patton would be a quick "go to" for an undercarraige. He would be for a deck, but shipping it would probably be killer. I don't know if you have a deck for your other tractor but you can but several different ones on the 782.
Old 05-21-2014, 11:58 AM
jimbob200521's Avatar
Nik,
Where at, Nik? Maybe I can help keep an eye on it for you!
-Ryan
Old 05-21-2014, 04:19 PM
nikster's Avatar
Thanks, but when I said local it's 12 miles from my house in the Fox Lake area.
NIK,
