Old 05-18-2014, 08:49 PM
hondaxr hondaxr is offline
Default Plastic Gas Tank
Have a Cub 123 with a completely rusted with holes STEEL gas tank! Do they make aftermarket PLASTIC tanks for these NARROW Frames or would a PLASTIC off a QUIET LINE series fit under hood of 123? I want PLASTIC ONLY!
Old 05-18-2014, 08:58 PM
I think if your looking for plastic only, your SOL
Old 05-18-2014, 09:02 PM
sawdustdad's Avatar
If not totally roached, the tank can be sealed with Red Kote. I did that to the tank on my 72 that had some pin holes in it. You can buy a qt. can of red kote from O'Reilly's auto for about $25, enough for a dozen cub fuel tanks.
But yes, you can buy a replacement tank from ccspecialties.org or one of the other sponsors. Or buy a used replacement from someone here or off ebay.
Check the for sale forum.
Old 05-19-2014, 09:03 AM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
KH-47-065-13-S
Only $320 +/-
Old 05-19-2014, 09:17 AM
I've never done it myself, but I feel pretty sure a QL tank will bolt right in on your 123.
FWIW, I'm not saying they don't/can't have problems but the metal tanks are pretty good, I have them on all my Cubs (except my QL).
Old 05-19-2014, 09:56 AM
garth68 garth68 is offline
i have replaced plastic tanks on some of my big walk behind mowers i use for landscaping. one had small holes the other one was braking down so small peices of tank got in fuel fillter so i would look it over good before you buy one
Old 05-19-2014, 10:22 AM
RLemke's Avatar
RLemke RLemke is offline
I know this may make the purists cringe, but i bought a plastic tank from Sears for $30. My metal Quietline tank was rusted inside and had holes in it also and I wanted to be able to put a whole new clean fuel system in it. Check out my album to see picks of the motor and tractor with the retrofitted plastic tank.
Old 05-19-2014, 10:33 AM
I've never seen a quietline with a metal tank.....
Old 05-19-2014, 01:24 PM
sawdustdad's Avatar
Now you have... Even if it's a bit of a "Frank"enstein tractor..
I wonder if a WF tank would even fit on a NF tractor? I certainly wouldn't mount a plastic tank on top of the engine as is done with the NF tractors.
Old 05-19-2014, 03:18 PM
What's that tank off of Frank?
