Old 05-07-2014, 10:52 PM
clay1811/44c's Avatar
clay1811/44c clay1811/44c is offline
Default Thoughts on 682+1811
The more I look at the 682 the more I want to keep it. I like my 1811 but the 682 just looks so tough. The 682 I was told the motor quit running. But haven't tried to start it yet. I bought it just for the 3 point hitch and few other parts that are better than the ones on my 1811.
So here is my idea. I have one 1811 that I had bought for parts but runs fine just a little rougher then my first 1811. What if I take the hydraulic lift off the 1811 and put on 682. Also switch over the m18 to the 682.
I'd have the best of both worlds. Cast iron rear end , strong m18, hydraulic lift and a tough looking red tractor.
Okay let's here the pro's and con's.
Old 05-08-2014, 01:04 AM
Well, then you'd have a 682 with a Mag. I don't see any cons here.......
Except you'd only have 2 tractors instead of 3!!
Old 05-08-2014, 06:54 AM
I say go for it!
Old 05-08-2014, 07:35 AM
jimbob200521's Avatar
I think the choice is obvious - I'd go for the red machine with a Mag and hydraulics any day!
-Ryan
Old 05-08-2014, 08:01 AM
Did I read here that the wiring was different going from the 17hp to the m18? Are their any other mod's I should watch out for?
Old 05-08-2014, 12:02 PM
I'd do it! Love the looks of the red cubs!
Old 05-08-2014, 12:44 PM
stown7 stown7 is offline
I agree...sounds like the way to go, and you'll basically now have a 782 with a Mag in it...not to mention the 3 pt hitch!
Old 05-08-2014, 01:58 PM
Use the harness and key switch from the 1811.....
Old 05-09-2014, 01:16 PM
Gregory Gregory is offline
Using the wiring from the 1811 might be a good idea. The 1811 has a magneto ignition, where the KT is point/condenser. The magneto doesn't require twelve volts off the key to generates the spark.
Old 05-14-2014, 09:34 PM
Just figured out I need to switch the Hydro unit, correct. Will it go from the 1811 to the 682?
