Old 04-29-2014, 10:43 PM
Southtowns27's Avatar
Southtowns27 Southtowns27 is offline
Default 149 tune up parts and cranks slow
Time to get the 149 ready for another summer. I'm looking for part numbers for the coil, points, and condenser. If anyone has Napa numbers, that would be even better.
Also, the thing seems to crank slow. The battery is new and all the connections are clean. Is the S/G possibly getting tired? Still seems to charge fine though.. Any thoughts here?
Old 04-29-2014, 11:15 PM
Are you partial to NAPA? I can give you Primeline part numbers and you can get them at O'Reilly's.
On the S/G pull it and clean the comm and brushes. You'd be surprised how much difference it makes. Plus, it grounds to through the case. When you take it off, shine the bracket and gen at the mount. Little rust there will slow it too.
Old 04-30-2014, 03:11 AM
TheSaturnV's Avatar
Or take your IH part numbers to TulsaEngineWarehouse.com
I think the condenser for instance is like $2.
Old 04-30-2014, 06:05 AM
Here is where you can get your Part Numbers........ Parts Look Up
Old 04-30-2014, 09:09 PM
Using that llink I was able to find the Kohler part numbers. I'm going to try Napa tomorrow to see if that have a listing or can cross them over.
J-Mech, I use Napa mostly since there's a store a mile away. I don't know of an O'Reilly's anywhere near here. Thanks for the advice on the S/G, I'll give it a shot.
Old 05-01-2014, 07:57 AM
snoel's Avatar
snoel snoel is offline
Could hydro linkage slightly out of "true neutral", cause some drag?
Steve
Old 05-01-2014, 10:59 AM
If the tractor isn't trying to creep when cranking, then no.
Old 05-01-2014, 11:54 AM
jkier's Avatar
jkier jkier is offline
I did a quick search but didn't find anything.
Has anyone done a write up of a SG rebuild?
I'd like to give mine a go thru, but don't want to let the magic smoke out when I hook it back up
106 Needs a clutch-------107 (Lent to my brother)
123 w/hydro lift & qa36--126 w/creeper and lift
127 restored--------------129 50" mowin machine
129 w/hydro lift-----------147 plow horse w/tiller
149 auction score---------782 KT17SII
