I have a lift bar the guy gave me when I bought my 782. I believe the bar is for a 682. My question is if I straighten the bend out of it, will it be the right length to work on my 782?
Does any one know the correct length of the 782 lift bar
Travis 1993 Cub Cadet 2064 1988 Cub Cadet 2072 1980 IH Cub Cadet 782 w/CH20 1966 IH Cub Cadet 102 w/K301 1961 IH Cub Cadet O 1967 IH Cub Cadet 102 & 122 JD 2155 w/ 175 loader |
Travis,
That bar is a WF bar. Yes, if you straighten the bar out then it should work on your 782. If someone doesn't get you the measurements I should be able to when I get home from work today. |
Thanks, Mike! I just want to be sure it will work before I straighten it. I think it's NOS. It was zero wear on it: biggrin2: I don't want to screw up a perfectly good part.
I agree Travis. I will measure one when I get home and let you know.
I measured one off a 782 Travis and it was 26-1/8" long.
Need anything else let me know. |
Mike, is that end to end, or hole to hole? This one is more like 27-1/4" end to end. It is 26-1/8" from the farthest part of each hole to hole, tho.
Each hole is 9/16" from the end of the bar.
Found this a while ago
http://www.onlycubcadets.net/forum/showpost.php?p=138690&postcount=2 From this thread http://www.onlycubcadets.net/forum/s...690#post138690
----------------------------------- 106 Needs a clutch-------107 (Lent to my brother) 123 w/hydro lift & qa36--126 w/creeper and lift 127 restored--------------129 50" mowin machine 129 w/hydro lift-----------147 plow horse w/tiller 149 auction score---------782 KT17SII |
![]() Any one need one for their 682?
