Old 04-24-2014, 10:15 AM
dbuck dbuck is offline
Smile Sltx1054?
I am looking for some information on removing the gas tank. I have the bracket off holding the tank, but can not get the tank out of the tractor. The reason for removing the tank is, dash lever for the parking brake (plastic) is broke behind the dash, not allowing the rod to engage. Any ideas/suggestions will be greatly appreciated. Thank you for your time.
Don B, USAF 1962-1968, Ft. Wayne, IN
Old 04-24-2014, 10:37 AM
Looks like you remove the screws #40 from #39 that are screwed into the up rights #31 & 32
Old 04-25-2014, 08:08 AM
Smile
Sam, Thank you for your reply. I have removed those screws and the bracket, but can not remove the gas tank. there does not seem to be enough room to pull the tank.
Old 04-25-2014, 11:12 AM
I wonder if you need to remove the engine or the dash tower? I've never worked on one so I'm not sure. I'd call Cub and ask them if it was me.
Old 04-26-2014, 06:06 AM
Smile
That the way its beginning to look. I am going to take your advice and call Cub, 1st thing Monday AM. Thank you for your reply.
