Old 02-19-2010, 06:37 PM
johncub7172's Avatar
Default K161 PTO and basket pully removal
When removing the set screws from the PTO, I found that they don't come out unless the hole in which they live is clean. So using a .30 cal.bore brush along with my drill motor, cleaned the holes out,and a follow up spray of WD-40, works super. As for the moment, while removing the eccentric collar bearing set screw, it simply snapped in two, and it was very easy to do and did not require any force at all to break. Now I'm stuck with trying to get the remainder of the screw out so I can proceed. These pics. should say it all. I will keep a post going on my experiences with this matter. Any advice is welcome, Thanks.
Old 02-19-2010, 06:59 PM
May I suggest this....
Works soooooooooooo much better than WD-40.
Old 02-19-2010, 09:51 PM
Sometimes it is possible to place a nut on the broken set screw then weld inside the nut to attach it to the broken set screw, and the heat from the welding usually helps also.
While it is warm, try to move it ever so little back/forth trying to break it loose. a vice grips works well here if there is room.
If the nut breaks off, try it again.
also, I have welded a flat washer on then welded a nut to it.
As thin as that collar is, you should be successful.
Luck!
Old 02-19-2010, 10:03 PM
Be sure to use some Anti-seize when you put that PTO, bearing, and starter pully & basket back on.
Old 02-19-2010, 10:25 PM
ihnick's Avatar
ihnick ihnick is offline
I use JB80 instead of wd40. way better
Nick.
Old 03-07-2010, 10:37 PM
Well, this project is now finished. I must say, it was very eazy and re-assembled correctly. Upon the broken set screw of the e.locking collar was filed flat, drilled, and a eazy-out made quick work of the set screw. Unbealievably the basket pully slipped off the shaft with out the use of any puller. It was fun to learn about the pto, bearing, etc., and all. So if anyone could use help with theirs, let us know. now I have is to set the pto engagement lever.
Old 05-18-2010, 07:28 AM
Well, here to find out I must have not reassembled the pto correctly because it stays engaged.
Old 05-18-2010, 09:17 AM
MBounds's Avatar
MBounds MBounds is offline
JohnCub: The PTO Clutch is engaged and stays that way when properly assembled. To disengage the clutch, the Wear Button must depress the Thrust Button.
Myron B
East Texas
Most of of the fleet:
Cub Cadets: 2 Orig,70,71,122,123,104,124,126,86,128, 109,800,1200,1250,1450,1650,IH 682,782D,IH 982. Cadets: 76,SO76,80,81,IH 182. RER: 60,75. Elec 95. Trailers: #2, #3, #4, 1200-A,1200-B,1200-C, 2000. IH 1210 P/U, an IH Scout II and an IH Scout 800 to tow 'em with.
