Old 04-21-2014, 08:57 PM
bocephus1991's Avatar
Default $47 pto switch?
Got the electric pto on my 1211 but the switch won't stay in the run position. Looked it up on the cub site and it's $46.63! That thing made of gold?
Brian
Old 04-21-2014, 10:39 PM
Was looking at tsc website. Would one of their toggle switchs work? How many amps is the oem one? They have several diff ones. Thanks!
Brian
Old 04-21-2014, 11:48 PM
cubby102's Avatar
cubby102 cubby102 is offline
A toggle would work but you would have to do some wiring
Old 04-22-2014, 12:46 AM
Brian,
The 1211 uses a "hold on" relay. The switch activates the relay and as long as all safety features are a "GO" the PTO is on. With a toggle switch, the relay would have to be bypassed and the safety switches wouldn't work. It would be as cubby102 says, "a little bit of wiring". The switches last a really long time and are worth replacing correctly.
Here's a replacement (part number sub) for about half....... Ebay
Old 04-22-2014, 06:20 AM
The 725-0893 is a OEM Switch and Cub Cadet knows this and charges what they do. Even though these switch is made by Indak, you would be hard pressed to find a suitable aftermarket replacement. The best you can do, is find it for the least cost.
Old 04-22-2014, 08:16 AM
Jonathan, could it be that the switch wouldn't stay in the run position because I was not sitting in the seat at the time? I was standing beside the tractor watching to be sure the pto was engaging. Maybe then nothing is wrong with the switch? thanks!
Brian
Old 04-22-2014, 09:12 AM
Yep that could do it. Try it sitting on the seat.
Old 04-22-2014, 03:22 PM
Thanks Sam,will give that a try. Been busy this morning maybe tomorrow night before I get to it. I kinda figured that might be the problem. I looked at it heck there's 6 wires going into that switch!
Brian
Old 04-26-2014, 11:06 PM
Tried the switch again I put a suitcase weight on the seat and the switch stays on.
So appears nothing wrong with it. Haven't had much time to work on the 1211 lately
Since starting a part time job.
Brian
