Old 04-20-2014, 05:57 PM
smr5529 smr5529 is offline
Default Cub 124 turning radius
Bought a Cub 124 over the winter. Started mowing with it this week. Notice that the turning radius is great when you turn left (almost turns too hard), but when you turn right you need a cornfield to make the turn: the wheels barely turn. Is that normal? Is something connected wrong in the steering box? Anyone have any ideas? Thanks.
Old 04-20-2014, 06:15 PM
cubby102's Avatar
cubby102 cubby102 is offline
Sounds to me ya need a adjust the linkage from the steering box to spindle. Fairly easy to do.
Old 04-20-2014, 06:38 PM
Thanks Cubby. Is there a FAQ or a service bulletin I can look at?
Old 04-20-2014, 06:45 PM
You disconnect the Drag link from the bottom of the Steering Column. You count the turns from R to L (or vice versa). Bring the Steering wheel to "mid point". Make sure the front wheels are straight forward. Then adjust the drag link to connect back up to the steering column. Wa-la...you are done.
Old 04-20-2014, 07:26 PM
Thanks Roland. Easy as pie...
