Welding on a pair of Xtreme's front wheel brackets. Does any one have the correct measurements pertaining to where these go in relation to the rear wheel brackets?
1- 1864 Dual hyd, cat 0, axle braces 1- 1450 Dual Stick w/ power steering 1- 1200 in pieces 1- 1864 in pieces QA36A Thrower, #1 Tiller w/ extensions, IH windbreaker, IH wheel weights, 44C mower deck, 50C mower deck, CCC 54" Blade, GT46 high vacuum deck, GT54 deck, Cub Tripple Bagger, Custom dozer blade, Custom suitcase weights, 3pt cultivator, lawn sweeper, original R-Bucket |
i just did this with some that i cut off an old gt deck... got the updated spindles to put in my 50a and the front wheel brackets...real cheap...anyways, i just held a piece of angle against the flats of the rear brackets, held it square, lined the fronts up the same, and 90 degrees from ground..thats where they were on the deck i cut them off of...understand?? basically in line with rears
Yeah, that's what I was thinking but on my gt 46" deck the fronts are set in more than the back. Classic case of over thinking. Thank you!
no problem bud...deck looks nice..is that for the 1450?? cant wait to get mine done
Yep, in line with the rears. I had a scrap 44A that had them on it. I cut them off and put them on my 50A that I refurbed
