I made a plow today. I ran the arms on the plow back to the arms that lift the mower deck. These arms are hooked to rods that allow 4 or 5 inches of movement
before they can put pressure on the arms, that would lift the mower deck, so their is not enough travel left to left the plow. H as anyone else come across this problem,and what did you do. Any help would be great. The tractor is a GT3200.
You did what?
It is a snow plow,i just want to lift it with the center hydraulics,like the mower deck.
You made a plow? How about a pic......
It's impossible for anyone here to know how you constructed your blade without some pictures of what you have done.
I think I have it figured out,it is the movement the deck hangers allow so the deck can float,i will weld a stop in their to take away some of the movement.
I assume there is a long slot that a pin slides in for float. I wouldn't weld anything permanent under there, still need the deck to float. Can you take two pieces of flatstock and sandwich the slot? You can bolt the flatstock together with two bolts through the slot to lock out most of movement. The blade needs to move up and down a little to follow the ground.
Bill |
