Old 04-09-2014, 10:48 AM
baybrio baybrio is offline
Default Is there a 48" deck?
Hi folks
Non mechanical owner here.
I own a 1000 that I've used for about 15 years. She finally let me know that she needed serious work so I've sent her to a great small engine mechanic. He has her running perfectly but says the current deck is shot - needs serious welding etc. So I'm looking for new deck.
From looking at the specs for this mower it can use a 38", 44" or 50" deck. My mechanic swears the deck has a 48" cut and is 50" wide.
Is there a 48" deck? And if there is how do I find it?
Thanks
Old 04-09-2014, 11:01 AM
The deck should have a tag on it with the model # I only see the decks you mentioned. Get us the numbers or some good pics and I'm sure one of us can help you.
Old 04-09-2014, 11:21 AM
OK, I'll see if go over tonight and get a pic and model number, thanks!
Old 04-09-2014, 01:06 PM
Someone could have put an older 48" deck on it. Pics would be most helpful in determining what you have.
Old 04-09-2014, 04:12 PM
PaulS's Avatar
PaulS PaulS is offline
According to Oscar Will's book the mowers available for the 1000 are: 38, 44(44a), 48 and 50 (50A) inch decks available.
Old 04-09-2014, 07:37 PM
gmbadgley gmbadgley is offline
If the spindles are still good, I would just get some welding done. Finding a reasonably priced good used deck in the spring could be tough.
Greg
"If I can't fix it, I can screw it up so bad no one else can either"
Old 04-09-2014, 09:21 PM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
http://mattoon.craigslist.org/grd/4413558226.html
Old 04-11-2014, 11:26 AM
Thank you PaulS. Ok, so I have a rare 48" deck.
I've found a 44" deck in working order close to me (thank you craigslist) so I'm going to get that for regular mowing.
Is my 48" something a restorer would be interested in or should I have it welded into working order and keep it as a back up?
Old 04-11-2014, 11:30 AM
Also thank you double07 for the link. I'm keeping the number for the future.
Old 04-11-2014, 11:42 AM
jimbob200521's Avatar
Hmm...did this person contact you about the deck and only send one picture with a foot holding the deck up?
-Ryan
