Old 04-05-2014, 12:44 AM
bocephus1991's Avatar
Default PTO Brake Cover
This may be a dumb question, so sorry if it is. I'm in the process of getting the 1211 ready to mow. The block is different from the k301 in my 1200, so instead of buying a new PTO clutch, I drilled some extra holes in the PTO plate #1 to mount it. Then got some studs and attached it. Problem is, the brake cover will not fit. I can't drill the brake cover to make it fit. Anyways questions is do I need the brake cover? Number 5 in the attached pic
Brian
Old 04-05-2014, 08:19 AM
gmbadgley gmbadgley is offline
Try running it with out it. If it works OK and you can live with out it so can I!!
Greg
"If I can't fix it, I can screw it up so bad no one else can either"
