Old 04-02-2014, 07:36 PM
jeb71 jeb71 is offline
Default Cub Cadet 70 help
I'm trying to remove the grill and removed 4 bolts. It's loose but wont come out. It rocks back and forth, but something is holding it in. Any ideas ?? thanks
Old 04-02-2014, 09:35 PM
Do you still have the mower deck mule drive on?The front bolts on either side have to be removed.
Old 04-02-2014, 10:10 PM
"you must unlearn what you have learned"
"learn from the master you must"
Seriously though good luck with your project. Have any pics?
Old 04-02-2014, 10:13 PM
mmzullo mmzullo is offline
The pto lever must be removed?
Old 04-03-2014, 09:00 AM
Are you trying to take the grill out, or are you trying to take the grill shell off?
Old 04-06-2014, 08:39 PM
think i got it . i didnt see the side bolts in the front, took them out and bang off it came. Then another newbie mistake, trying to get the engine out i took off the 4 bolts from the top, engine was loose, but it would not come out and split at the bottom. I didnt see the bolts coming through the bottom into the lower part of the engine which holds it to the from. Uncle ( esarvey) should of been there for this. I wil post pics when the new engine is in place. thanks everyone
Old 04-07-2014, 04:18 PM
Glad to hear you got it! Thanks for the update!
Old 04-07-2014, 09:46 PM
X2!
Old 04-16-2014, 01:17 PM
esarvey's Avatar
esarvey esarvey is offline
Wink Live & learn
Remember GRASSHOPER , U are the one who shoehorned an LT1 into a RX-7 body , U will not fail in this engine swap , SLOW and think it through , as Ole -unc is with U all the way !!!
DaDuke of
2145,1864,1811,1810,1541,1330,1210,1020,1641,147,1 24,73, IH FARMALL CUB. 7254, 1863, IH 982
