Old 04-01-2014, 12:41 PM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
Default Can I test the starter solenoid if I.......
run a wire from battery positive to the small terminal on the starter solenoid?
Without burning something ?
on a CC-127
Old 04-01-2014, 12:48 PM
Yes....
But, just touch the wire to the solenoid post. Don't hook it up.
Old 04-01-2014, 01:10 PM
DoubleO7's Avatar
yea just to see if the solenoid kicks in.
right now via key switch it does not even click.
But if I turn ignition on and jump positive to the big terminal on the start-gen, I can start and run.
And turnoff via ign. switch.
Old 04-01-2014, 06:37 PM
Sounds like you have an issue with start only circuit, possibly brake switch and or connections. Lew had a cool test if you don't have a meter, put an automotive style spade fuse like a 15 amp in the wires after you disconnect them from the brs. It jumps them out safely if you are a jumper kind of guy
Old 04-01-2014, 07:00 PM
Or get one of these.........
Old 04-01-2014, 07:41 PM
What end does that probe go into ?
Up to 530 and counting...
Old 04-01-2014, 08:00 PM
DoubleO7's Avatar
brake switch works per meter.
I have a pointed end test light to for stabbing wires or finger when it slips.
P.O. installed a red dash light to show if key is on.
Key is getting power per the light.
Charge gauge moves a bit.
It has the very frayed cotton insulation wires.
I think a wire too or from the brake switch is broken.
