Old 02-13-2010, 08:44 AM
ab147's Avatar
ab147 ab147 is offline
Default Elec Lift on 147
I'd like to say Hi to everyone here, been reading through alot of posts, and it looks like this is the place I want to be.
I have a cub 147 that I've had since the late 80's, and have suffered through the usual breakdowns; spindles, mowerdeck bearings, carb cleanings, but now i've run into something I need help with. The electric lift has failed, and living in Michigan, it helps to have a snow plow. I need some direction on taking this lift apart to see what has broken, and how it can be fixed. Right now the lift is extended, and will spin when energized. Before I took it off the tractor, it wouldn't do anything. Thanks in advance for any and all suggestions.
AL
Old 02-13-2010, 10:23 AM
Does this help...??
Old 02-13-2010, 12:59 PM
ab147's Avatar
R Bedell,
It sure does, any way of naming the numbers so I know what each part is. Thanks
I got a general information booklet from a friend that has blown up detailed drawings of the inner and outer workings of the lift. Thanks
Old 02-13-2010, 03:05 PM
dclinansmith dclinansmith is offline
Default 147 Electric Lift
ab147, Your electric lift should be manufactured by Duff Norton, Pn MPD 6405-6.
Go to their website and you can download a manual with repair instructions and a parts list.
Old 02-21-2010, 09:32 PM
LDPosse LDPosse is offline
Wow, thanks for that great info, I didn't realize you could still buy these brand new!
2008 Suzuki Hayabusa 1340cc
2007 Toyota Prius
2003 Suzuki DR650SE
2001 Chevy 2500HD 6.0L
1979 IH Cadet 85 Special Go Kart
1971 Buick Skylark 455
1971 Cub Cadet 147
Old 07-31-2010, 11:05 PM
ab147's Avatar
any idea on the price?
