Old 03-22-2014, 01:14 PM
Default Can anyone ID these weights?
These came on my 800. They seem to be at least 50 lbs each if not more. Someone said early on maybe Wheelhorse? I thought I saw an option one time of IH weights that we're double the size of the normal ones but these don't have IH on them anywhere And no access to lugnuts while on either so probably not. They have relief cut in them for valve stem so I don't think they're homemade. Thanks, Mike
Old 03-22-2014, 02:44 PM
Homemade,,,JMHO!
Old 03-22-2014, 09:41 PM
I agree with CAD.
Old 03-22-2014, 11:04 PM
X3
Is that one weight?
Or two stacked up?
Old 03-23-2014, 10:06 AM
gmbadgley gmbadgley is offline
If they were cement I would say homemade, but they look like iron to me. It looks like slight rust on the top. That would take a lot of machining to make, not your basic DYI job. I would almost bet they were from a large tractor that just happened to have bolt holes that line up. Possibly Oliver, I think they used a green about that shade.
Greg
"If I can't fix it, I can screw it up so bad no one else can either"
Old 03-23-2014, 11:12 AM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
Those sharp edges tells me they are plate steel?
How big are they?
The outside shape is odd for purpose made wheel weights.
They might have been slugs dropped out of cuts made for something else.
And then altered for wheel weights versus scrap bin.
Old 03-24-2014, 12:09 AM
Yeah, I'm bettin they are made from something else, maybe like 007 says, something that would have otherwise ended up in the scrap bin.
Someone did do a pretty good job on them though... I would use them.
