Old 03-18-2014, 10:09 PM
rdehli rdehli is offline
Default 451 blower on a 782-1812
Will a 451 blower fit and work on a 782 or an 1812? thanks Rob
Old 03-19-2014, 06:50 AM
Rob,
The 451 is for the 6" pto's and if your 782 or 1812 have the original engines then you need the 450 for the 4-1/2" pto's.
It will physically hook up but won't be turning at the right speed.
Old 03-19-2014, 07:15 AM
Sam Mac Sam Mac is online now
Or just change the PTO.
Old 03-19-2014, 08:04 AM
is there a pulley on the blower itself that can be changed to make it the correct speed?
Old 03-19-2014, 10:12 AM
I'm pretty sure you have to change the gearbox Rob.
Old 03-19-2014, 10:29 AM
If I'm thinkin correctly my 1812 with the 4.5" pto clutch will turn the blower a little bit faster , than say a 1863 with the 6" diameter pto clutch... Right?
Old 03-19-2014, 10:56 AM
Yep it would be running at about 130% of normal speed. Just my 2 cents but I'd look for a 6" PTO.
Old 03-19-2014, 11:23 AM
will I need the whole clutch or just the pto pulley. Never had one of those apart. All mine work great.
Old 03-19-2014, 12:10 PM
cubs-n-bxrs's Avatar
No sir you have it backwards. It would be running 70% of normal speed. A smaller drive pulley means less belt is travelled in one revolution hence slowing it down. If a smaller pulley was installed on the driven end it would speed it up.
Old 03-19-2014, 12:19 PM
so in other words Im just fine just not gonna throw the snow as far. correct.
