Thread Tools
Display Modes
I have a model 86 that I just replaced the teaser spring, Throw Out bearing, and clutch disc on. I may still need to adjust the clutch linkage, but I noticed after getting everything back together that the entire throw out bearing looks to be turning against the hinged plate. I noticed some sparks, and the bearing getting hot. I'm not sure if this will wear away eventually, or if something isn't right. The clutch engages and dis-engages like it should. any help is appreciated.
Something is wrong. Look in the tech section for the manual and take a look or post some pics of what you have.
Definitely post some pics of what you got.
Should have about a 1/4" of space or less between bearing and lever. Adjust clutch per the manual.
DWayne 1973: 128, ag tires, 3pt. lift, spring assist, lights, 42" Deck 10" moldboard plow 2016 XT1 42" deck 18HP |
I think I may have found my problem. When I compared it to my 128, I noticed the 86 was missing a spacer, that on the 128, the teaser spring lays inside it, and the spacer is between the clutch rod, and the rear clutch disc plate. My 86 now has a 10hp in place of the factory 8hp, and could explain why this spacer was gone and why I now need one???
![]() Quote:
