Papaw 1984 CCC 582 w/ creeper, 42" blade, 44C deck, 220# wheel weights, 2 link chains & adjusters, Spring assist lift. ![]() |
This is what I did for a rear lift.
http://www.onlycubcadets.net/forum/s...=20585&page=15 Post #148 shows the mounts.
You could also remove the whole rear lift bracket (the one that mounts to the seat frame) and run an actuator from there (run the pin through the mounting hole in the actuator) and bolt the other end where the lift straps attach to the briny adapter.
Cub 104 Refurbed Sprinig of 2013 Aftermarket headlights, 3 point, Brinly Adapter, Spring Assist, 42" IH Blade, 42" Mower Deck, 42" Craftsman Grader Blade, 10" Brinly Plow, 6-12 ags and 22x9.50 turfs |
Is it a cat 0 3 point or IH lift? If it is the IH lift, I agree with Sam and vartz. A winch or actuator from the top hitch mount to the sleeve hitch is easier. If it is a cat 0, you would need two actuators? One for each lift arm. When you chain up the front blade do you disconnect the lift rod? If not, can you just reach down and turn the pacman wheel to keep the blade up instead?
Bill |
No, it's the IH lift. I think I'm going back to mounting a 3rd hydraulic valve on the fender and using a 149 or 1450 lift cylinder in place of the lift arms. I have the valve already.
I have seen pictures of Cubs with a separate lift cylinder for the three point. Keep in mind that it has got to float.
Thanks Sam. I hadn't thought about that.
