Right now I have a 42" blade on my cub cadet 100, and I would like to get a blower for it. Will the qa42 work?
Yes, the QA42 is a listed attachment for the 100.
I wouldn't recommend it. A 10 hp doesn't have the power to make good use of the 42" snow thrower. I recommend nothing less than the 12 hp. Of course it depends on the depth of your snow, but if there is enough snow to use the QA42, then there is enough snow to warrant greater hp from a K301.
Just my $0.01, since I am too poor to give my $0.02... Cub Cadet 123
I will say a 10 hp is gonna be working awfully hard, and you are going to have to go slow.
I have a strong M-18 and I can pull it down to stall with a 42A if I am not carefull. You can take partial cuts. |
I appreciate the opinions. I kind of figured it would be a little much for a 10 horse. I might look into getting another cub such as a 149 with a blower. The last thing I want to do is wear out my 100, because my great-grandpa bought it new in '64 and means a lot to me.
Why not a qa36? It's better sized for 10 hp and I assume it is the same mount?
Bill |
Same mount. Either a QA36 or QA36A will work. ( substitute 42 for wider thrower )
I might have too see if I can find a 36, the reason I asked about a qa42 is I found one for sale in my area that was cheap.
