Old 02-08-2014, 05:22 PM
donnelly.me's Avatar
donnelly.me donnelly.me is offline
Default Rear lift for a 149
I have been getting interested in getting a rear lift for my 149 but i have some questions. If I have it on will it go up and down when I raise and lower my plow? Do they attach together somehow? Or would i have to take it off when plowing snow?How much weight can they lift? Thanks, Mark
1973 Model 149
42" Snow Blade
John Deere X360
John Deere 10 cu Poly cart
Squire Applegate 5HP recoil start
Old 02-08-2014, 05:54 PM
Muzzy Muzzy is offline
It will go up and down with the plow but, there's no need to take it off. They can lift around 350 lbs. Maybe more.
Your question is confusing.....
Yes, the front and rear will lift together.....
When you raise your "plow" are you referring to the front mounted BLADE?
No, unless you have an implement on the rear such as a plow, tiller, or something else you wouldn't have to take anything off. If you have an implement mounted, then yes you would.
How much will it lift? What are you wanting to lift? It will pick up all attachments made for the cub cadet, and a few more......
Old 02-08-2014, 06:44 PM
Sorry about the confusion. I did mean the front blade. I was just curious about the lifting capacity because I was thinking about adding a weight box. Thanks,Mark
1973 Model 149
42" Snow Blade
John Deere X360
Old 02-08-2014, 06:48 PM
Add weight to the tires. Either wheel weights or fluid. Don't hang it off the rear lift. No reason in the machine having to lift all that extra weight. Weight of the blade and weight on the rear is just asking for something to fail.
Old 02-08-2014, 06:56 PM
plus your arm will prolly fall off...
Up to 530 and counting...
