Old 02-05-2010, 08:43 AM
dieseldog558's Avatar
dieseldog558 dieseldog558 is offline
Default engine overhaul kit
just wondering has anyone bought an overhaul kit from ebay...the seller is the mans one stop shop...he has a complete gasket kit,oil seals,rings and a piston for 54 dollars,,,just wondering if anyone knows how good this kit is....thanks
Old 02-05-2010, 06:30 PM
Merk Merk is offline
Is this the kit in question?
http://cgi.ebay.com/fits-Kohler-Engi...item1c0fdac2fb
Keep in mind the following pertains to my everyday/stock rebuild Kohler motors.
There is more to rebuilding-overhauling a motor than what this kit has in it. The following parts need replaced when rebuilding a Kohler motor:
piston
rings
connecting rod
governor-(if it is a plastic gear)
gaskets
crankshaft seals
new head bolts
Depending on how the parts look in the crankcase breather they may need replaced. I like to replace the crankcase breather filter when I rebuild a motor.
Odds are the valves will need ground or replaced and the valve guides will need replaced. The guides may be ok now....2 years later the guides will need replaced.....easier to replace now than 2 years from now.
I only use Kohler replacement piston(s) in my Kohler motors. The kit says the piston is top of the line....Kohler piston cost more and the quality is better.
I do not install a used connecting rod in a rebuilt motor. The material will weaken over time. The only connecting rod I will use in my Kohler is one made by Kohler. I had a few friends bring freshly rebuilt motors over because they had a knock in them. The Stens rod was the problem.
Best thing you can do is spend a few extra dollars on the good parts.
Old 02-05-2010, 08:49 PM
By the time you buy his "add ons" (just the ones HE has listed) you're already at almost $200.00 I think you can buy Kohler stuff for "darn" near that much.
