Old 01-10-2014, 07:52 PM
dbuck dbuck is offline
Smile PTO removal question:
Having trouble removing the pto on my K321 which is in a CC149. Have all the allen screws out and it will woble but can get it to release from the bearing. The reason for removing is to replace the bearing. Any suggestions or ideas on removing the pto will be grealty appreciated. Thank you for your time.
Old 01-10-2014, 08:08 PM
You do have all 6 set screws out correct? It will need to come out straight and not at any kind of an angle. Use some PB as well. Sometimes the clutch disk catch inside the basket too.
Old 01-10-2014, 08:15 PM
sawdustdad's Avatar
You know there are two set screws in each hole, right? one on top of the other. Assuming you get all six out, here's what I do. I take about a 2 foot piece of 1x2 (hardwood like maple or cherry if you can get it). Then use that like a drift to "knock" the clutch off. Put one end in the pulley groove, find a direction (I usually work from the governor side) and lay the stick back against the block as far as you can. Then tap the end of the stick to drive the pulley (and clutch) off the bearing. Tap, rotate, tap, rotate, tap, rotate, tap a little harder if you have to...etc. until it come off. You are using the stick and a hammer to drive the clutch off, if that all makes sense.
Then you will need to remove the bearing....remove setscrews from the black eccentric locking collar behind the bearing, then using a punch, knock the black ring counter clockwise to loosen it. (usually it's counter clockwise, I had one that was the other way). Once the locking ring is loose, use a gear puller to pull the bearing off the shaft. the locking ring will come right off as well.
Removing the clutch basket is a challenge. Remove the set screws, then, with a helper, using two long (3-4') wrecking bars/crow bars, get behind the basket as close to the shaft as you can, from opposite sides, and pry the basket off the shaft. Use heat on the basket if you have to. I've had to mount the block in a big woodworking vise or set in on a very sturdy workbench, and with the help of another person, both of us putting our considerable weight on the pry bars, to pop the basket loose.
heat, a few hammer taps to the hub, and lots of penetrating oil can help.
Good luck!
PS, there is a good utube video that you might want to look at. search for cub cadet pto removal.
Old 01-10-2014, 08:16 PM
Two in each of the three holes. Thread size is 1/4-20 NC and the hex wrench size is 1/8"
Old 01-10-2014, 08:22 PM
Good luck!
For the clutch basket I used my homemade puller to remove the pulley. I drilled it with a "F" drill (.257 ) {a 17/64" (.265 )} will work and tapped the basket 5/16-18 NC
click for bigger pic
Old 01-10-2014, 09:17 PM
sawdustdad's Avatar
That's an elegant solution! I like that much better than brute force. I'll try that next time. Thanks for sharing, Jeff.
Old 01-11-2014, 08:43 AM
Good luck!
I've utilized an old wooden hammer handle that will no longer support a hammer head.
Old 01-11-2014, 10:28 AM
Smile
Thank you everyone for your replies. I will take your suggestions/ideas an give it another go.
Old 01-14-2014, 09:00 AM
Glad to report that the PTO has been removed and the bearing replaced. Used red oak dowel to force off. Thanks again everyone for the suggestions and advice.
Old 01-14-2014, 10:10 AM
TheSaturnV's Avatar
Excellent news, good job.
