Old 01-05-2014, 02:42 PM
hattrick4467 hattrick4467 is offline
Default 105 Hood and Pivot repair?
The hood on my 105 has the pivot holes torn out. There are just long standard bolts in the pivot holes. Any recommendation or pictures for this repair?
Old 01-05-2014, 03:19 PM
I normally cut out the rusted area and replace with new metal. Drill a new hole then weld a washer on the backside. There really isn't any other way to repair to torn out area.
Old 01-05-2014, 03:41 PM
Muzzy Muzzy is offline
That's pretty much all you can do.
Old 01-05-2014, 04:24 PM
Can I buy the original grommets or bushings that were used?
Old 01-06-2014, 01:40 AM
They originally had a very thick "washer" welded on the inner part of the hood. If you really take your time you can probably duplicate the way it was. I think all of the tractors that I own, that have been repaired, are pretty sloppy.
You may be just as well off to find a good used hood.
